RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 07-05-2006 | 08:18 PM
  #91
RTK's Avatar
RTK
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
If you can make it run perfect on the ground, but it gives you fits in the air, I would not mess with the pop off pressure.
There is an external force making it run poorly in the air, that being air pressure (+ or -).
ORIGINAL: jongurley
It possibly could be a pop off problem,,
