RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Not arguing at all.
The point I am making is if it will run on the ground perfect then it is not a pop off pressure problem. You are changing the pop off pressure to compensate for a pressure gradient problem, not a pop off pressure problem.
