RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 07-05-2006 | 11:50 PM
  #101
srm99
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
NOT A 3W OHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
ALL I AM SAYING IS THE metering spring will be forced open with the vacuum and yu can make more tention on the spring not muchbut a little and what u are doing if weird airflow on dirafram its not going to open the neadle .
there is a simpler way turn the carb plate around and test as weird airflow is not the same everywhere .
like i said if u want tonow if it is weird airflow put a round bandaid yes baindaid on the dirafram hole the doa test flight .
plus gravity has a bit to play with the metering spring as a knife edge is a high G and the weight of fuel pressing on the metering valve can make it not completly close in so flooding the engine . so a higher spring tention will make the fuel flow more consistant .
