RCU Forums - View Single Post - Removing Gears from Clutch Bell
Old 07-06-2006 | 12:52 AM
dustin7837
Default RE: Removing Gears from Clutch Bell
You will need to pull the engine off the magnum.
Then You should just be able to get them off by undoing the one screw that goes through the center of the spurs. THen they just come off. You mihgt have to give them a little pull and wiggle because there are 2 bearings in there and sometimes they fit fairly snug.
