RCU Forums - View Single Post - Aileron Hook Ups
Old 12-30-2002 | 02:20 AM
Wamp
Default Aileron Hook Ups
Thank you for your replies.
What are barn door aileorns? I did a search and came up with confusing results.
The box said, that you could set up flaperons.
The skysport6 does have flap control on it but appears that a seperate servo is needed.
Channel 1 is ailerons and channel 6 is flaps. thanks for that info. But can you mix the 2? In other words, can you mix the 2 channels togther to make it work, or is a diffrent radio needed. I have the manual right in front and it says nothing about mixing.
Pardon me if I am going off the wall with this. Thank you for all your help.
