RE: Throttle stick
You can add more spring pressure if you just open the transmitter and gently bend the spring to put a little more pressure on the ratchet of the throttle. If the transmitter is well-used, it could be that the ratchet, itself, is worn. In that case you'd have to replace that part of the throttle gymbal. That can be done for a nominal charge at the service center.
