ORIGINAL: aerobob
Personally, and NO offense meant to anyone (and yes, I've shared this view with Scott).....
Angled intake tubes, called "stacks" are not induction rams. They have no venturi. They either create turbulence at the butterfly, or PREVENT turbulence at the butterfly. They either increase power, or they do NOTHING. They keep the plane cleaner, or they make it more difficult to choke. Or maybe easier to choke.
Point is - post a poll in the Gas Engines forum about the benefits, and I'd bet a broke prop that the results will only tell you about people's "beliefs" on these things. They aren't a gimmick; I'm not saying that.
ZDZ designs and sells true "intake Trumpets", that are installed on their REAR intake motors (means carburetor intake is inside the fuse) and those things DO make a difference. They also are a true venturi shape that has been engineered.
A piece of round tubing of some length (BTW - all "stacks" seem to be the same length, regardless of the motor they are installed on. Would make one wonder about "tuning", no??) stuck on the end of a carb just gets in the way in most motors. Vast majority of guys aren't gonna carve up a cowling to have a piece of tubing stick out. I won't, anyway.
Like I said - this feature is a "belief system".... for some it is "gotta have", for others, a "who cares"..... if it makes a difference on your motor, and you like it, then it "works", and is "needed". If not, well, you're in the same place as about 95% of the other gas engine owners....
Bob - I'm kinda with you on this, and wouldn't be opposed to taking the 26's trumpet off and not cutting the hole in my cowl if performance remained the same- but, the Zama carb doesn't have a choke - Is there a good way to choke this engine without having direct access to plug the carb opening?
Oh, and I'm still wondering what the difference is between my 26 and Zippi's - why the line running out of the carb goes to the fiber block on his, and to the crankcase on mine.
RCU won't let me upload a pic - so I'll link to it instead:
