RCU Forums - View Single Post - New Engine Break in On or Off
Old 01-17-2003 | 02:41 AM
  #70
Whirley Bird
Default New Engine Break in On or Off
Originally posted by Destructor
WB Hope you got that!
It now lowered down to 2".
One inch per wing.
Have not flown it yet but really don't expect much because the leading edge is so thick.
I measured the Avistar also and it looks so flat so I tacked a string to one wing tip and pulled it tight and tacked it to the other.
The clearance between the center where the wings butt together measured out to just under 5/8 on an inch.
Also the wing is thinner.
The OS-46 should make it a snappy little trainer. PLEASE NOTE!!!
I REDUCED THE DIHEDRAL FOR MY OWN EXPERIMENTAL PURPOSES *ONLY*
USUAL DISCLAIMERS APPLY
Sorry,
Had to put that there because my other post was removed
