I have an MDS 148 on mine. I fly in Denver at 6000' above sea level. Nice vertical.
Plane is turned upside down. It's a low-wing taildragger.
Had to add a bit of down thrust in the engine after I turned it over. The firewall has about 1 degree of downthrust built into it. So, when I turned the plane upside down, I needed about 2 degrees of downthrust to correct it.
I placed some hard plywood in the saddle where the horizontal stab is supposed to be. I mounted a Klett tailwheel. I glued the horizontal stab to the top of the plane where the tailwheel would have mounted; had I not flipped things.
Dual elevator servos and pull-pull rudder.
It's pretty cool. Flies nice, but kinda heavy at 10 pounds.
