RCU Forums - View Single Post - Hangar 9 Pulse XT 40
Old 07-10-2006 | 10:23 PM
HughBrown
Default RE: Hangar 9 Pulse XT 40
I put a Saito 72 on my pulse and how I did it was to first turn the Carb around so the throttle lever was to the right side of the fuse and then rotate the lever 180 degrees so it points up. After that I took the dremel and cut a small notch in the firewall in line with the throttle linkage and install Sullivan Golden Rod between the Throttle servo and the Throttle. I also rotated the servo output arm 180 degrees and the rod passes nicely above the tank and up to the engine. make sure you use the clips that come with the metal clevices.
Hope that helps.
