RCU Forums - View Single Post - Sealing the engine
Old 07-11-2006 | 04:04 PM
kx250ryder's Avatar
kx250ryder
Default RE: Sealing the engine
It does help. Any airleaks in your fuel tank, fuel lines, or the engine itself will cause the engine to run improperly. I forget the particular reason, but "sensor safe" silicone is the type you need to use.
I believe this is the thread you were talking about:
http://www.rcuniverse.com/forum/m_37...tm.htm#3794678
