g-38
jbflier, the G38 is a 2.3ci engine, and while it is not quite as powerfull as the Brison 2.4 should make a wonderfull combination for either the Kangke Hurricane or thier new 120 size Cap232. They both have large interiors making it easy to move rc gear around for balance. Lots of control surface and light strong construction. Both planes are very docile in flight when set up conservitivly but when you step on the throws and move the cg the only limiting factor will be your skill. If your G38 runs good go ahead and use it, you'll have a blast.
