How To Make A Glow Engine Run Faster
What kind of engine is it, and how many RPM's is it turning already?
To get faster, to an extent, you can turn off CapsLock, run higher nitro %, add a
properly tuned pipe, change the gearing in the car, or do some fancy machine work.
Obviously, if it's slobbering rich, you can lean it out a bit... though don't overdo it.
If it's already leaned out too much, and sagging on top end, try richening it up a bit.
You'll have to be more specific on what the symptoms are, before anyone can help much.
