How To Make A Glow Engine Run Faster
HI HOW DO I MAKE MY ENGINE RUN FASTER RIGHT NOW IT DOES NOT GO AS FAST AS ITS SOPPOSE TO GO. HELP
[email protected]
[email protected]
My Feedback: (10)
GA
What kind of engine is it, and how many RPM's is it turning already?
To get faster, to an extent, you can turn off CapsLock, run higher nitro %, add a
properly tuned pipe, change the gearing in the car, or do some fancy machine work.
Obviously, if it's slobbering rich, you can lean it out a bit... though don't overdo it.
If it's already leaned out too much, and sagging on top end, try richening it up a bit.
You'll have to be more specific on what the symptoms are, before anyone can help much.
