RCU Forums - View Single Post - Knife Push-Pull
Thread: Knife Push-Pull
Old 12-31-2002 | 05:20 AM
theKAT
Default Knife Push-Pull
Here's a "real" Knife.
This is top of wing, looking down.
Aileron servos are outboard. Rudder and elevator are inboard, throttle is in the middle on the right side.
Spacing is determined by:
Rudder/elevator- leave enough room to clear the fuse with your servo arm
Ailerons- So the control horn on the plans lines up with your servo arm
Throttle- close to the inner as you can get without interfering with the pull-pull arm (throttle is push-pull)
