RCU Forums - View Single Post - Engine Troubles
Thread: Engine Troubles
Old 12-31-2002 | 04:56 PM
JimFranks-RCU
Default Engine Troubles
Check the position of the fuel tank if it higher than the carb that is your problem, also check that your lines of kinks. If the vent line is obstructed that will cause it to. Have a similar problem with a fuel tank that is to close to the firewall and the vent line got a kink in it till I moved the tank back and reran the lines.
