RE: Throttle-cut on twins
If you have a 9C, you can mix the slider to the second engines channel at 20% them do a pmix with the second engines channel as slave and channel 3 as master at 100%. Then you can control the second engine with the throttle and the slider as a fine adjust for the throttle of the second engine.
