RE: 12Z Flaperon Programming
Hi MSBOB,
How is your radio reacting? Are you gettting Aileron action? Did you make sure to use the 2 Aileron wing type? Have you tried setting this up using your Airbrake menu? Try that and see if it works for you, if you do, make sure that you have it activated, and set your percentages in "Tuning" not in Offset as there is a mistake in the FAQ for Airbrake...
Let us know more of how you have this set up, Krysta
I am trying to set up Flaperons using the CAMBER MIX MENU. The ailerons are working normally. I have looked at the Futaba 12Z FAQ site but the insructions for doing this were not detailed enough for me.
I have Flaperons setup on the 9C and I am trying to duplicate this operation on the 12Z.
Any help will be greatly appreciated.
[/quote]
