RE: Velocity Stack on MVVS 26
forget the washers, but save them for later.
The carb is centered by bosses on the bolts.
You need to carefully position the velocity stack, so it will not interfere with the choke plate. Best is to close the choke, then open it slightly and finally tighten the nuts when all moves freely.
