RCU Forums - View Single Post - Storing 2m Pattern Models
Old 07-14-2006 | 03:56 PM
Mastertech's Avatar
Mastertech
My Feedback: (31)
Default RE: Storing 2m Pattern Models
I did at one time use two angled brackets covered in foam but I found after extended stays the fuse warped. My shelfs are about 24" wide so the stab does stick over a bit. One good thing about this system is it allows you to use the "Shelf" as an extra work bench or storage area if there's no fuse there. I covered mine in cheap carpet.
