Uproar 60 wing improvements?
I'm about to start a Uproar 60. Had a question on the wing. It is held together by a 1/4 20 nylon bolt that is screwed into each of the wing halves, and CA'd in place. To lock the wing in, a aluminum tube, a stabilizing dowel, and the bolt are the methods. I wasn't really to keen on glueing the bolt in, since if I needed to replace it, I'd have to tear up the covering. I was thinking about putting a blind nut on the inside of the wing and screwing the bolt into that. Any Ideas or sugestions?
Here's a pictrue of it from the plans.
