The HSN affects the LSN that is why all recommend adjusting the HSN first. I recommend you but everything back to factory settings and start tuning all over starting with the HSN. If you still have problems after doing that check for air leaks.
Sounds like you are on the right track and it is what is called a false idle.
This may help.
http://www.*********.org/cars_eng-tuning.htm
