RCU Forums - View Single Post - CT5 two speed transmission
Old 07-17-2006 | 10:28 AM
porsche996
Default RE: CT5 two speed transmission
take the transmission apart and make sure those two tiny ball bearings are in place under the allen screws on the clutch. sometimes if you take it apart those things can fall off and theyre tricky to get back in. if theyre not in, the wont come out of first gear, or they could be jammed under there somewhere locking it into second gear (which would explain the bogging). hope this helps
