Multiplex Easy Star Interference Issue
Has anyone ever experienced an interference/glitching issue with the Easy Star? I'm using a Futaba 3-CH radio and Futaba R-114 receiver (single conversion) Every now and then, the motor skips for a split second. And once or twice per flight during climb, the motor skips a bit longer and the plane tries to roll right. (I can't see it but pretty certain it glitches the servo.)
The capacitors are soldered to the motor as they're supposed to. Would a dual conversion receiver such as the Electron 6 fix this problem? Or is there something else that can be done to cut down on the apparent "noise?"
