Multiplex Easy Star Interference Issue
TX
Has anyone ever experienced an interference/glitching issue with the Easy Star? I'm using a Futaba 3-CH radio and Futaba R-114 receiver (single conversion) Every now and then, the motor skips for a split second. And once or twice per flight during climb, the motor skips a bit longer and the plane tries to roll right. (I can't see it but pretty certain it glitches the servo.)
The capacitors are soldered to the motor as they're supposed to. Would a dual conversion receiver such as the Electron 6 fix this problem? Or is there something else that can be done to cut down on the apparent "noise?"
GA
I found that if you add another cap or 2 it will greatly reduce or even eliminate the noise, some people have wrapped the servo wires with aluminum foil but I tryed that and it made things worse, just make sure none of your servo wires cross each other or the antenna and make sure your control rods don't touch, if all that is good add a capp or 2
