RCU Forums - View Single Post - setup help os160 w/ vp30
Old 07-17-2006 | 11:47 PM
Planeclothes's Avatar
Planeclothes
Default RE: setup help os160 w/ vp30
I too had to set the idle needle several turns in. The high speed needle is usually set slightly less than one turn open. ALWAYS check the integrity of the pressure line (engine to pump). If the pump stops working while the engine is running it will run dangerously lean and possibly damage the engine.
