RCU Forums - View Single Post - Multiplex Easy Star Interference Issue
Old 07-18-2006 | 07:19 AM
AJ1202
Default RE: Multiplex Easy Star Interference Issue
I found that if you add another cap or 2 it will greatly reduce or even eliminate the noise, some people have wrapped the servo wires with aluminum foil but I tryed that and it made things worse, just make sure none of your servo wires cross each other or the antenna and make sure your control rods don't touch, if all that is good add a capp or 2
