RCU Forums - View Single Post - 2M Weight Question
Old 07-18-2006 | 04:22 PM
mmattockx
Default 2M Weight Question
Just curiosity here - why do current 2M planes weigh significantly more than the previous generation ones? Is it simply the extra fuse volume that is doing it, or are the bigger engines also adding in their share? For instance, a 2M Sequel has 968sq in, 74" span and 77.5" long. Generally similar dimensions to the current 2M planes, except it had a much narrower fuselage and a 120 for power. AUW was around 9.5lb. Currently, it seems that most of the 2M glow powered planes are coming in well over 10lb and they are using fixed gear instead of retracts. What's up?
Mark
