RCU Forums - View Single Post - HELP PLEASE- genesis differential
Old 07-19-2006 | 11:04 PM
monstatruCkin
Default RE: HELP PLEASE- genesis differential
the shims i took out are destroyed because i drilled out the screws and 1 didnt drill out so i was trying to "twist" the gear off the case and the shim bent badly. ill just put it together without the shims and ill see how it does. thanks for the help
