RCU Forums - View Single Post - charging batterys
Old 07-21-2006 | 04:29 PM
MikeEast's Avatar
MikeEast
Default RE: charging batterys
what charger are you using? You can charge lithium ion packs with a Lithium polymer charger. Jan already told you what you need to verify before charging. It is critical that you use a charger that is setup for Lithium packs otherwise you can explode the pack. Be totally sure before you try to charge. Lithiums are really safe, when handeled properly.
