 charging batterys >
charging batterys
charging batterys
Old 07-21-2006 | 07:00 AM
My Feedback: (48)
Default charging batterys
Can I charge 7.2V lithium Ion batteryes with a Liop charger>> my charger does have adjustabul charge rates and will do nicads > nic-cad or lipoes>>
Old 07-21-2006 | 10:31 AM
Default RE: charging batterys
Hi!
You can charge a Litium ion battery with a Lipo charger!
Beware that you must tell the charger what Voltage and Ampere to charge with! For example a 11,4 volt, 450 mAh Lipo battery is charged with 11,4 V and 450mAh (Or any ampere below that value). A 7,2V , 450mAh lipo battery is charged with 7,2V, 450mAh (Or any ampere below that value).
Regards!
Jan K
Old 07-21-2006 | 04:29 PM
MikeEast's Avatar
what charger are you using? You can charge lithium ion packs with a Lithium polymer charger. Jan already told you what you need to verify before charging. It is critical that you use a charger that is setup for Lithium packs otherwise you can explode the pack. Be totally sure before you try to charge. Lithiums are really safe, when handeled properly.
Old 09-03-2006 | 06:11 AM
hi well i say polymer lithium ion or lipo and i found these amazing ones the other day and just made the order so i will keep you updated on tem as there a new company so not sure on the quality yet. and lipo is fine if you use the right charges. check them out worth a look i think www.electrolite.eu
Old 09-03-2006 | 10:09 PM
My Feedback: (48)
I went ahead and bought a charger designed for lithem-ion a multiplex LN-5014>>> it is working very good>>> and I feel more confident knowing that it is doing the right job for the right batts>> thank you for your responce
