CAP 232 / OS FS70II combo
Hello:
I recently finished a Nanlong CAP 232 .46 size, and mounted a new OS FS70II Surpass engine on it. The plane has a wing span of 55", and the weight came in at just under 7 lbs. This plane is recommended for a .46 2C , or .52 4C. Does anyone know what kind of results I can expect with this combo? The prop is a 12X6. Also, OS recommends that the break-in prop is a 11X9. Can I use the 12X6 for the break-in? Radio system is a Futaba 7CAP. The weight was 6 1/2 lbs, not 7. Sorry.
Thanks!
