RE: throtle servo
Metal gear servos usually have at least one plastic gear. That helps a bit.
The sparks in the brushes of the servo can cause serious problems. Fortunately its easy to shield them. Just ground the motor case. There is usually a large value capacitor in parallel with the brushes to help eliminate the problem. If that gets broken off you have a noise source that can drive you nuts.
