RCU Forums - View Single Post - flatout setup
Old 07-23-2006 | 04:29 PM
SS2P's Avatar
SS2P
Default RE: flatout setup
Yep, cut off the landing gear and make there small foam pads. It is fine in stock unless your flying it on high rates ( stick in the corners)!!! I've done just a little beefing up to it. you don't need 4 servos... you need 3.. If you plan using 4 then get a 'Y' harness and maybe even servo extensions... Oh yea, get some CA glue too! And prop / adapter.
Which one id you choose by the way. I have reflection...
I just came from flying it, and I made a "pancake" crash lol.
Paul
