RCU Forums - View Single Post - How to build a stand for rc airplanes???
Old 07-23-2006 | 11:51 PM
bigtim
My Feedback: (13)
Default RE: How to build a stand for rc airplanes???
my method cost a little bit more but works well, if you buy 2 shelf standards the kind you screw to the wall studs from Home Depot or local hardware store, screw to the wall at 32" apart in the studs. then get pipe insulation 1/2" works well to pad the brackets with, cut it to length and slip over the bracket ends for padding . you yhen can add as many brackets for wings and fusalages and adjust acordingly keeps it all neatly stacked and out of the way.
