RE: Corny Panzer from Walmart.
I wanted to add something...use rechargable batteries and you won't need to do that remove two batteries mod...since I've changed mine over the run time has increased
and throwing the tracks are almost nill...I find after a good run to check the tracks alignment..I took mine in tall grass, up the hill on the side and then through the dirt with is really loose and the traction is excellant!!!! I think I might look into modding this tank with a few options once I see the insides..
My wish list is the following:
1. smoke generator
2. firing airsoft gun.
3. metal tracks if possible.
4. add driving lights
outside of that this tank is solid.
Mark
