RE: G230 PORTING FOR TORQUE
well there is other porting styles that can add low end power, liek adding hooks(hangers) to the transfers. or porting the transfers to have more of a rounded shape and no so squared and the port walls.
i wouldnt suggest running the G23LH Piston in any type of RC Cylinder because you WILL catch the ring, even if you flip the piston. the only way you could probably use a LH Piston in an RC Engine is if you have a Trevor Simpson Casereed and havent cut the 5th or 6th ports in the cylinder yet.
you could also add a reed valve but you have a change of intake velocity being slower.
