RCU Forums - View Single Post - H8 question !
Old 07-25-2006 | 03:08 PM
46u's Avatar
46u
Default RE: H8 question !
ORIGINAL: Nitrohouse
With the stock shocks, and stock un-drilled pistons you'll want to start with 30-35wt up front, and 25-30wt in the rear. The stock piston holes are only 1.2 mm and oils any thicker than what I listed will feel too thick...Most are drilling the pistons to 1.4-1.6mm and using thicker oils for more consistency...Hope this helps...
Have Fun...Burn Nitro...
Thanks and that makes a lot of sense! Trying to find out all I can before I get mine so when I go to building and setting up I will be in the ballpark on my first trip around the track.
Thanks!
