RE: GV-1 Governor set up problem
Thx Gnichola,
Yes there is ample movement. I also tried setting the idle position much higher to see if that would enabling programing the stop farther down from idle but still that did noty work. There was servo movement for sure on the initial setup from idle to engine cut off. Its the actual setting that I use to turn the engine of from idle presently.
