9z saving freq and ppm-pcm settings
I have a 9zapwc2. I have 7 planes in memory. When I select a new plane that is on different channel, or pcm-ppm setting, I have to manually change both settings. Am I doing something wrong? You would think that each models saved memory settings would include the channel it is on, and the correct ppm-pcm settings.
