RCU Forums - View Single Post - Voltwatch Question
Old 07-27-2006 | 12:24 PM
Gremlin Castle
My Feedback: (14)
Default RE: Voltwatch Question
Units such as the I-4C product give an exact system voltage reading accurate to .01 of a volt. They show the system and the draw of each surface as it is actuated. If you care to, you can add additional mechanical load to a surface with you fingers and see what that load looks like.
It gives a dynamic picture of the system versus a fixed reading found on an ESV. I use the Futaba voltage checker on some of my planes and onboard voltage indicators on others. Since neither is a potential point of failure during flight it comes down to whether the use of either is an added step of diligence or just a ritual that gives us a little more confidence before flight.
ORIGINAL: mglavin
Gremlin,
The simple fact is these devices cannot or do not display the actual voltage under static loads and or whilst stirring the sticks, as I eluded to. Granted this information is better than nothing... The response time, sensitivity and graphical representation of these devices are lacking for our purposes IMO.
I feel the loaded voltage via an ESV is a much better indicator for our needs, simply because we can view numerically the actual system voltage verses a loosely calibrated graphical display range and sustain the load indefinitely if so desired, this provides an indication of the batteries current potential under load. Which again is not necessarily the best method, but is a field performable means to an end after and or prior to flight.
