On an EI system a low battery in flight will result in a few misfires and then a dead stick. On a twin cylinder many times one cylinder will drop first. On the ground you will get a few pops and possibly a short run before the flash voltage goes south. The I-4C would be the best product as it would give an actual voltage reading with the engine running. The bottom line however is start with a good pack and check it every few flights. The Onboard indicator is an option not an absolute necessity.
You can check the models under my profile and see that I am flying several sizes with EI,s and voltage indicators. What I have posted here is direct experience not conjecture or hearsay. For reference I started using a locally made onboard monitor in 1991 and have used various ones since just because I can.
ORIGINAL: Bosch232
For the record, I was asking about the Voltwatch for the E.I. pack as Magna stated above.
I'm setting up my first E.I. engine, and I'm unfamiliar with the current draws involved, or the implications of a battery failure in this application.
But I do find the other debate interesting.
