RE: world war 2 fighter
You can have a small opening in the front underside of the cowl on the spit.. This is to let air in.. then you need an outlet. I made a duct thru the firewall and then the fuse behinh the cylinder. This duct exits the fuse at the wing leading edge where the oil cooler is located.
