RCU Forums - View Single Post - help with robart hinge points
Old 07-29-2006 | 09:46 PM
RVM
Default RE: help with robart hinge points
Do you have to actual joint of the hinge buried halfway into the surfaces? What I mean is this: the metal hinge pin that holds the two parts of the hinge together should be right at the edge of the surface of wood that it is in.
