RE: help with robart hinge points
If you have that big of a gap something is not right. I have used then a few times and can get 0 gap with them.
I find the biggest problem with them is you need to taper the hole some otherwise you cant slide them in all the way. Also try to make it so when there in the hole you can slide them in so the leading edge is at the center of the pin as thats the pivot point..
Pat
