RE: annoyed with locktight on Nemesis diff case
go to radio shack and buy the soldering torch kit or use a torch lighter. thats the only way i removed those stubborn screws. it will require alot of heat to remove the green loctite, you will almost hear and see the loctite boil up around the screw, thats how you will know its time to remove it. be paitent though you dont want to destroy the o rings either.
