RCU Forums - View Single Post - buggy to truggy
Old 07-31-2006 | 01:16 PM
{GBI}Harryball's Avatar
{GBI}Harryball
Default RE: buggy to truggy
15Tooth clutch bell should get you the low end you want.
This is from chubbysuncle from another thread Hope it helps. Looks like it will have to be a single speed only.
Are you talking Tornado XL? If so I don't know if there's a 2 speed clutchbell available that will fit. I believe that for the single speeds an HPI clutchbell will work. I will do a test fit on the Volcano next time the engine is out but the 18 t spare that came with my Savage looks like a perfect fit. FYI the #'s are HPI A990 for 15t and A993 18t. Those are standard bells. The HD racing bells are 13t #77103, 14t #77104, 15t #77105, 16t #77106, 17t #77107, 18t #77108, 19t #77109 and 20t #77110. These are start outta the Savage parts list. Single speed only!
OK clutch spring broke on the Volcano 2nite....SO....18 tooth HPI clutchbell just fits. I believe that this has been posted before but I can verify! . Bell does rub upper support a little but it works. The truck flies! Check the vid thread!
