RCU Forums - View Single Post - Sullivan remote glowplug connector>
Old 01-21-2003 | 12:34 AM
Carlos Murphy
My Feedback: (72)
Default Ditto...
It's the same thing with glow starters, not all will hold onto all types of glow plugs.
As far as the remote and onboard system connectors go, I have found the Maxx Products connector #ACC133 to work with all plugs.
The wire for the connector goes through the side of the connector and is spring loaded and and grabs onto the center electrode holding it in place.
If the electrode is a short one as on some plugs you just cut off some of the bottom of the rubber housing and it will fit just fine.
I've seen one system where a guy coated the end of a wire with solder and attached it to the electrode with a small wheel collar.
