RE: double elevator servo Hookup?
Hi, Dave:
The elevator is a split elevator, so each servo mounts in the fuse, one on each side of the fuse, mounted on the outside, set into the fuse servo opening, which are located under the stab. Flipping a servo end for end still makes the servos counter rotate, each going in the opposite direction. It doesn't change the rotation direction of either servo. Does that make sense? Thanks!
