RCU Forums - View Single Post - annoyed with locktight on Nemesis diff case
Old 08-01-2006 | 06:47 PM
efretwell
Default RE: annoyed with locktight on Nemesis diff case
I worked on the front diff and the rear diff with three seperate torches, I would heat a screw with one torch until the lighter was to hot then I would switch torches, after going through a lot of butane I gave up, having only loosed one screw after a couple of hours. I plan to try again sometime with a high wattage soldering iron. That locktite is the devil to get off.
